M340 Arrays
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • M340 Arrays
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Posted: ‎2021-05-06 12:17 PM
1
1804
M340 Arrays
Array.pngsamplingBlock.pngGood evening,
I have written a DFB which captures values from a sensor into an Array.
I'm capturing the values every second , however I have noticed that the values keep on changing latency when it has been captured in the array. Is there any way I can restrict the values not to be changing once they are written. This is the block which is capturing the values . One other thing is Test_Data_Out[1] gets over written every cycle.
Trinxs1
Trinxs1 Leader
Leader
Posted: ‎2021-05-09 04:06 PM
Hello BGB,
I would look to synchronise the update of the DFB, using the second pulse to trigger the operation of the block.
The scan cycle of the system is in order of top to bottom in the application browser so please ensure that the source information is provided at the top of the scan and the update of the DFB is at the end of the scan.
If using inputs please check the update of the input is associated with the task that you are running the DFB in.
Finally I would use an IN_OUT connection for the array attach the array to the input side so that the data array can be read into the array and also updated internally.   If it is attached as an output only any changes you make to the array externally to the DFB are overwritten by the DFB.
Trinxs
Trinxs
Senior Technical Sales Consultant - PAC
