Continue
  • My Subscriptions
  • Events
EcoStructure Control Expert v15.3 Does not Compile Libset v13.0 and earlier
Modicon PAC Forum
  • Industrial Automation
  • Modicon PAC Forum
  • EcoStructure Control Expert v15.3 Does not Compile Libset v13.0 and earlier
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Rick2
Rick2
Explorer
Posted: ‎2024-05-23 03:19 PM
1912
Literally the title. I just want a simple answer to this situation and support wont answer it.
I have a program written in EcoStructure Control Expert v15.3 for an m340 v3.3.
I want to build the program so that it is compatible with libset v13.0. This is simple for every other libset version. The compiler has no issues until I downgrade to v13.0 and earlier. All of these libsets throw a Linker error during compile time.
In order to force the libset to compile I must delete all logic programs. Then the program compiles with all of my auxilary stuff, DTMs, drives, NOC, IO, etc.
It seems the compiler is missing a referenced library for these earlier libset versions.
Linker - Unresolved External Symbol: "_Pou_Copy_PARAM"
  • 06. EcoStruxure Control Expert
  • m340
MatthewM
MatthewM
Mentor
Posted: ‎2024-06-06 01:24 AM . Last Modified: ‎2024-06-06 01:25 AM
I have used new ECE to open very old programs with old libsets without issue, but I have never tried to downgrade the libset before.  I know you can choose to upgrade the libset, so why not downgrade it via the same method?
You could try this:
From the Start menu > Ecostruxure Control Expert > 'Libset Installer' and check that libset v13 is installed.
Then open ECE, and File > Open, and navigate to your file, but don't open it yet.
Select the file, then down the bottom select "Select a specific target version", and choose v13.0 from the drop down.
I just did a test run on an M340 program, and successfully downgraded and built a v14.0 libset program to libset v13.0.
Ricard
Ricard Troubleshooter
Troubleshooter
Posted: ‎2024-06-11 01:29 AM
Hello
I had a similar case and we solved it by exporting it to a ZEF file and importing it in again. Sometime the files get corrupted.
BR
Ricard
