Send Data to FTP Server display
Manage Alarm Actions
Send InviteCancel
Define the settings for a Send Data to FTP Server alarm action on the server.
A name field, severity selections, and the "Alarm Action Scheduling" display that all alarm action types share, are also available.
Primary and Backup tabs
You must define at least the Primary tab elements.
Note
The only difference between the two tabs is that the Backup tab includes backup settings.
Setting
Description
FTP Server Hostname
Identify the hostname or IP address of the FTP server that will receive the data.
User ID
Identify the user identification needed to log on to the FTP server.
Password
Identify the password needed to log on to the FTP server.
Verify Password
Retype the password.
Target Directory
Identify the relative directory path to be used to store the data at the FTP server. This should always be a path relative to the default directory associated with the user ID used to log on to the FTP server.
If the directories on the path do not exist they will be created automatically.
Note
This Target Directory field accepts macros.
Base Filename
Identify the base filename to be used for storing the data at the FTP server.
Alarm data will be stored in a file with this name, followed by the *.nbalert.xml file extension.
