Alarm macros for SMS email alarm action settings on the DCE server
Manage Alarm Actions
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • Manage Alarm Actions
  • Alarm macros for SMS email alarm action settings on the DCE server
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Manage Alarm Actions
  • Mark as Read
Sisko JLehr Sisko
‎2024-01-31 08:47 AM
Three basic types of macros can be used for Send Short Message Email and Send Data
to FTP Server alarm action settings: Location, Identification, and Alarm.
Location macros
One location macro is available for use when defining alarm action settings for SNMP and
Modbus devices monitored by the Data Center Expert server.
Macro Definition Example
${LOCATION}
The location for a Data Center
Expert SNMP or Modbus
device.
Test Lab
Identification macros
Identification macros are available for use when defining alarm action settings for SNMP
and Modbus devices monitored by the Data Center Expert server.
${SERIAL} The serial number of the device WA0450123456
${IP} The dotted-decimal IP address
of the device
192.168.2.23
${HOSTNAME} The hostname of the device device.apc.com
${MODEL} The model of the device Symmetra 80K
${SERVERIP} The dotted-decimal IP address
of the Data Center Expert
server
92.168.2.10
${SERVERHOSTNAME} The hostname of the Data
dce.apc.com
${SERVERMODEL} The model of the Data Center
Expert server
Data Center Expert
${TIMESTAMP} The current UTC time (seconds
since 1/1/1970)
998885130
${DATE} The current date (year-month-day) 2024-01-31
${YEAR} The current year 2024
${MONTH} The current month (2-digit
number, January=01).
01
${DAY} The current day of the month (2-digit number). 31
${TIME} The current time (24-hour, hour-minute-second 23-30-01
${HOUR} The current hour of the day (2-
digit, 24-hour time)
23
${MIN} The current minute of the hour 30
${SEC} The current second of the
minute
01
Alarm macros
Alarm macros are available for use when defining alarm action settings on the Data Center
Expert server.
${ALERTTYPE} The type of alert HIGHERR
${SENSORTYPE} The type of sensor generating
the alert
TEMP
${SENSORVAL} The value reported by the
sensor generating the
alert
60
${SENSORVAL_NOLABEL} The value reported by the
sensor generating the alarm,
excluding special characters
81.2 rather than 81.2 ° F
${ALERTTIME} The date and time the
alert notification was generated
Jan 12, 2024 13:01:45
${ALERTSEV} The severity value reported by
the sensor that is generating the alert (such as ERR, WARN,
INFO). If the alert state has
returned to normal, the severity
value will be followed by "-RTN"
(for example WARN-RTN).
ERR, WARN-RTN
${ALERTSEVNAME}
The ${ALERTSEV} value,
displayed in the language
appropriate for the Data Center
Expert server locale.
ERROR, WARN (returned to
normal)
${SENSORNAME}
The name of the sensor
associated with the alert
Bldg. 3 Door
${NOTIFPOLICY} The name of the notification
policy that was used to generate the alarm
Default, Policy #1
${ALERTTITLE} The alarm title Replacement Battery Needed
${ALERTDESC} The description, and
recommended action, if any, for
the alarm
At least one faulty battery
exists.
Recommended Action:
Replace all faulty batteries.
You can use the APC UPS Replacement Battery
Selector to order new batteries.
${ISACTIVE?yes?no} Specifies custom active vs.return to normal text. The strings “yes” and “no” can be replaced with user-specified “active” and “cleared” strings. For example, if you specify “active” and “cleared” for the “yes” and “no” values and the macro is translated, if the alert is still active the word "active" would appear and when it has returned to normal, the word "cleared" would appear. “active” and “cleared”
${USERURL} The user-specified URL that
can be defined within the
threshold configuration.
http://www.mysite.com
${USERDESC} The user-specified description
value that can be defined
within the threshold
configuration
“Too high”
${START_TIME} The time the alarm
condition was initially detected.
13:01:45
${RESOLVE_TIME} The time the alarm
condition returned to normal
13:07:13
${SENSORLUID} The locally unique ID of the
TEMP1
${SENSORGUID} The globally unique ID of the
B000113_TEMP1
${EVENTID}
The unique 16-character
identifier shared by all
messages generated as a result
of a single alarm notification
event.
For example, if an
appliance generates an alarm
notification when the internal
temperature sensor threshold is
exceeded, and then generates
a "return to normal" message
when the temperature drops
below the high threshold, both
of these messages will have the
same Event ID number.
However, if the temperature
rises again and a second
threshold exceeded alarm is
generated, the second alarm
will have a new Event ID.
3E4512C0FE03440F
${DEVICELABEL} The label or value of the device
that either contains the sensor
that reported the alarm or to
which the sensor is connected
My Device
${ALERTPOD} The label or value of the pod that either contains the sensor that reported the alarm or to which the sensor is connected My Pod
${ALERTPODSERIAL} The serial number of the pod
NB007100730114
${ALERTPORT} The serial number of the pod
NB007100730114
${ALERTPORT} The label value for the external
sensor port to which the external sensor that reported the alarm is connected
Ext1
${CURRENT_ALERT_NUM} The number of times the alarm
action has been repeated, from
0 up to the Repeats value for the alarm action
0, 1, 2
${RESOLVEUSERID} The user ID that is responsible
for manually resolving an alarm
(when this option applies)
joeuser
${RESOLVECOMMENT} The text entered into the user-specified description field
whenever an alarm needs to be
manually returned to normal (an
option that can be selected
whenever a threshold is
configured)
“Turned on the A/C”; “Fixed the
leak”
