Alarm Action Schedule display
Manage Alarm Actions
Send InviteCancel
Define the specific periods of time, for each day of the week, during which an associated activity will be disabled (by default, scheduling is enabled 24 hours a day, seven days a week).
Note
This display is used to schedule when an alarm action will be enabled and disabled, using the action's settings display.
The table provides cells for 15-minute increments, and columns for every day of the week. You can do all of the following to schedule when an alarm action is enabled:
Click a column title to enable or disable all of that day's cells.
Drag your mouse from one cell to another cell in a column, to enable or disable a set of cells.
Drag your mouse from a cell in one column to a cell in another column, to enable or disable an identical set of cells for each of the selected days.
