Unable to add tm3xfhsc202 as TM3 Module in Machine Expert
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Unable to add tm3xfhsc202 as TM3 Module in Machine Expert
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
EcoStruxure™ Machine Expert
Logic Controller - Modicon M241
Back to Machine and Motion Control Forum
Rbhegwood
Crewman Rbhegwood
Crewman
Posted: ‎2025-04-17 01:08 PM
840
New to Modicon PLC. I am unable to find tm3xfhsc202 HSC specific Device within the Machine Expert Software. I am able to see a HSC TM3XHSC202. If I add this software indicates I have an IO configuration Error
Thank you
  • Technical Support and Troubleshooting
  • M241
Marian_Pavlik
Ensign Marian_Pavlik Ensign
Ensign
Posted: ‎2025-04-22 12:58 PM
682
As written in datasheet https://www.se.com/us/en/product/TM3XFHSC202/
Module TM3XFHSC202 is compatible with Modicon M262 only.
Marian_Pavlik
Ensign
683
Rbhegwood
Crewman Rbhegwood
Crewman
Posted: ‎2025-04-23 09:17 AM
In response to Marian_Pavlik
Thank you @Marian_Pavlik I did determine that later as well. Not thrilled with distributor support on these. Unit has high speed inputs 0-7 so card is unneeded as well.
Regardless Thank you for the time! it is appreciated
