XUPH001 Experience in Mode 4 (PLC mode)
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • XUPH001 Experience in Mode 4 (PLC mode)
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Back to Machine and Motion Control Forum
Posted: ‎2020-01-21 03:01 AM . Last Modified: ‎2020-10-06 06:38 AM
5
3591
Does anyone have experience with configuring the XUPH001 in PLC mode?
This is the communication module for a pick-to-light system.
I'd like to connect it to a Modicon controller (e.g. M241) through a MODBUS connection.
How to configure the READ/WRITE holding registers, how to configure the system?
I'v read the manual, but do not fully understand... 😞
Can anyone provide me with some example code to get started?
Is there a function block available for this module?
Many thanks,
Best regards,
Mr. Tape
  • Modicon M2xx
Replies 5
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2020-01-30 03:19 AM
hey @Oncom , any idea on how to help @Anonymous user  here?
thank you
Oncom
Commander Oncom
Commander
Posted: ‎2020-02-02 07:30 PM
@Anonymous user Hi,
You can use IO Scanning instead of using Function Block in M241. it is more easier if you are new with Machine Expert (v1.1).
I will share it in video after this.
www.pamtek.co.id
Oncom
Commander Oncom
Commander
Posted: ‎2020-02-02 08:07 PM
2
3546
www.pamtek.co.id
Posted: ‎2020-02-03 12:33 AM
In response to Oncom
1
3539
Hello Sir,
I've done about the same in SoMachine... I only need to configure the IP and the unit ID....
Then I get the Device inputs and outputs...
The question still is how to read e.g. the status of the sensors, or activate the LED's in the sensors...
A programming example would be nice....
MAny thanks,
  • XUPH001
Oncom
Commander Oncom
Commander
Posted: ‎2020-02-03 01:35 AM . Last Modified: ‎2020-02-03 01:42 AM
In response to Anonymous user
Hi @Anonymous user
I'm not familiar with XUPH001.
but after read the manual, if you already set to PLC mode. you can read from register that you mentioned (%MW18,19,20,21).
for direct access to bit, you can access/read from %IX and %QX for WRITE or you can map it to variable (recommended)
and here is the example to read status from sensor, then latch it 2 seconds to light on LED status
if you need to check the program: example code - machine expert 1.1
www.pamtek.co.id
