TM3BCEIP alternative
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • TM3BCEIP alternative
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
Posted: ‎2021-08-11 01:49 AM
1350
With the global shortage of TM3BCEIP is there an alternative way  to manage Ethernet/IP and Modbus TCP communication when using TM3 expansion modules in a distributed architecture?
  • Modicon M2xx
LeTomas
Lt. Commander
Posted: ‎2021-08-11 03:16 AM
Hi @Anonymous user ,
I believe the easiest solution to replace the TM3BCEIP is to use another PLC M2xx as dummy remote IO so you can still use the TM3 IO modules as we have done in the past before having the Bus Coupler.
Best regards,
Leandro
Posted: ‎2021-08-12 12:33 AM
Thanks for the response, thought this might be the case.
Svenmj
Ensign Svenmj Ensign
Ensign
Posted: ‎2021-08-12 01:32 AM
Alternatively you could use TM5. I Don't know how the situation is on delivery on this product line.
You can configure using the PLC Configurator
https://www.se.com/ww/en/work/products/industrial-automation-control/tools/modicon-plc-configurator....
BR. Sven
