Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Reading ASCII data NOM 0200 in Control Expert
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Reading ASCII data NOM 0200 in Control Expert
  • Subscribe to RSS Feed
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
emir31
emir31
Cadet
Posted: ‎2024-08-09 05:46 AM
383
Using Control Expert, I am trying to read data in ascii format coming from a receiver using NOM 0200 serial connection. I have a ADDM block and a READ_VAR block where GEST are set to %MW100:4 and RECP is a receive buffer array size [1,7], enable bit is high, OBJ is '%MW', NUM is 10 and NB is 7. I have not been able to succeed. Is there an alternative approach I can take? Thanks.
  • Digital
  • Modicon M2xx
sesa333653_brid
Crewman sesa333653_brid Crewman
Crewman
Posted: ‎2024-08-10 01:41 AM
Hello Emir, if you are using ASCII messaging then READ_VAR function is not suitable for you. First you need to define the NOM's channel you are using as Character Mode Link. Second you need to complete the channel parameters definition which should match the parameters of the connected device. Finally, you should use the INPUT_CHAR function to read the received characters from the NOM's buffer. Best Regards.
This is a heading
