Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
M262 "Cannot get OPC UA Server parameters", OPC UA Server parameters not kept in offline project or CPU.
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • M262 "Cannot get OPC UA Server parameters", OPC UA Server parameters not kept in offline project or CPU.
  • Subscribe to RSS Feed
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
EcoStruxure™ Machine Expert
Logic/Motion controller Modicon M262
Back to Machine and Motion Control Forum
bond
Crewman bond
Crewman
Posted: ‎2025-03-10 03:59 AM
177
With Machine Expert v.2.2.2 and a M262 I can not seem to save/keep my filled in OPC UA settings in MyController.
Each time I close and reopen MyController and go to "OPC UA Server Configuration" tab, it shows an invalid configuration.
Even when I use the button "Reset to default", I can setup all fields like Security Policy, Message Security, ... But when saved and/or downloaded, it does not seem to store/save.
Anyone with same corrupt OPC UA config which seems unstorable ?
Is this OPC UA config setting screen stored offline in file or online in the CPU ?
Is there a way to reset/clear a bad OPC UA config ?
I had this problem in the past, though it was related to a M221 to M262 conversion. So i manually created a new project and copied my code again into a new clean project. Problem was gone for a while, but now it has returned somehow.
  • Modicon M2xx
  • CodeSys
  • M262
  • MachineExpert
  • OPC-UA
Francesco_Begnoni
Support
Posted: ‎2025-04-16 01:11 AM
Hello @bond ,
this seems a wrong behavior.
Can you attach here a project that has the issue? What is the M262 model?
I would ask you to create an official ticket for Schneider Electric Support.
Please, follow this link and provide your contact info: https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
You will be contacted as soon as possible.
Regards
Francesco_Begnoni
Support
Hello @bond ,
Regards
This is a heading
