M251 Modbus server fc4
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • M251 Modbus server fc4
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
Posted: ‎2020-07-08 07:39 AM . Last Modified: ‎2020-10-06 06:38 AM
3025
can be set, to make the modbus server respond to function 4 (read input register ) ?
Thanks.
  • Modicon M2xx
Replies 5
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-07-20 06:58 AM
@AmeliaFaraci : Could you help?
Rodrigo G.
Industrial Automation Community manager
LeTomas
Lt. Commander
Posted: ‎2020-07-21 12:11 AM
Hi @Anonymous user ,
If you take a look in the page 104 of the "Modicon M251 - Logic Controller - Programming Guide" :
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=EIO0000003089.02.pdf&p_Doc_Ref=EIO0000003089
If I am not wrong based on the document the FC4 is not supported for Modbus TCP Server but if the client uses FC3 you can move the %IW to %MW in the controller.
I hope this helps you.
LeTomas
Lt. Commander
Posted: ‎2021-01-20 11:55 PM
2514
A workaround could be the use of the ADDM and READ_VAR function blocks, please find below the link to download the example:
https://schneider-electric.box.com/s/bfg5ow6frqlr0lhkhweokic0j25qqg2t
If you do not know how to import it in your project you can take a look in the next video:
https://schneider-electric.box.com/s/4bvegb89udef194mavkubonmoc6pb2of
Best regards,
Letomas
Posted: ‎2021-01-21 06:23 PM
In response to LeTomas
Hi Le Thomas,
Thanks, I'll give it a go.
Louis.
Lindamartin
Crewman Lindamartin
Crewman
Posted: ‎2022-07-04 12:02 AM . Last Modified: ‎2022-07-04 09:20 PM
@Anonymous user wrote: MyAccountAccess Mobile App
Thanks.
The Modicon M251 Logic Controller implements both client and server services so that it can initiate communications to other controllers and I/O devices, and to respond to requests from other controllers, SCADA, HMIs, and other devices. Without any configuration, the embedded Ethernet port of the controller supports Modbus server. The Modbus Client/Server is included in the firmware and does not require any programming action from the user. Due to this feature, it is accessible in RUNNING, STOPPED and EMPTY states.
