LXM32 TM221 PTO Drive Problem
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • LXM32 TM221 PTO Drive Problem
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Back to Machine and Motion Control Forum
Posted: ‎2020-05-20 10:40 PM . Last Modified: ‎2020-09-10 12:42 AM
3
4466
I have TM221C16T and LXM32CU90M2. I want to drive my servo with PTO. I connect to servo with SoMove and run, no problem. Then I write PLC program in SoMachine Basic. I used MC_POWER_PTO,MC_MC_MOVEVEL_PTO. I entered all parameter. But servo motor turn slowly .. I don't understand why do it ?
  • Connectivity
  • Lexium
Posted: ‎2020-06-16 12:38 AM
Hello @Anonymous user ,
As a default settings Lexium32 C Scaling values are ,
As you can see ScalePosNum is 1 and ScalePosDenom is 16384 , that means 16364 pulse equals to 1 rev..
And you are using TM221C16T , in that case you are sending Pulse and Direction via fast outputs.
You can find M221's  fast output kHz information.
For example if you are using 100 kHz output for Pulse and direction ,
100000/16384 =6,103515625 rev /sec  , and  x 60 = 366,2109375 rpm
You are going to take this output.
To increase the velocity you can decrease ScalePosDenom. Lets see what happen when we adjust ScalePosDenom as 2000,
100000/2000 = 50 rev / sec     => 50 x60 sec= 3000 rpm ,
As you can see you fastest output can give 100000 hz output and if your revolution pulse value is 2000 pulse ,
You can take 3000 rpm as an output.
BR
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-05-27 12:54 AM
Hello @AmeliaFaraci, could you help on this?
Thanks!!
Rodrigo G.
Industrial Automation Community manager
BR
Oktay
Oktay
Cadet
Posted: ‎2023-12-17 02:08 AM
Merhaba TM221 plc ile lxm32ad72n4 kodlu servyu nasıl kontrol edebilirim bilgi verir misiniz TM241 ile CanOpen yardımıyla çok yaptım ama TM221 ile yapamıyorum daha doğrusu bilgim yok yardımcı olursanız sevinirim
