How to write the counter value into Modbus register
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • How to write the counter value into Modbus register
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Logic Controller - Modicon M221
Back to Machine and Motion Control Forum
Posted: ‎2021-11-02 03:42 PM
3570
It is my first time using Schneider PLC (M221) and Machine Expert Basic. I used another system that works very differently.
I am running a counter and I want to write the count value to a Modbus register. It will act as a slave where my other Modbus TCP master device can read the value in real-time over the network.
I am having trouble getting the counter value written to the Modbus object. Is it possible for this product/software? If so can someone give me some pointers?
Also, is it true that the counter object only has the maximum value of 9999?
Thank you
  • Modicon M2xx
Bastian_Schmitz
Admiral
Posted: ‎2021-11-03 07:03 AM
If you want to made the counter value available via modbus you need only to use a fixed memory value in which you write the acutal counter value. You could seen this in the follow expample picture.
via *.V could you read the acutal value of the counter back.
In the Sample picture I use a memory word on address 0. This is available via Modbus FC3 if the Server functionality is activated for the line. Modbus TCP server must be manually activated.
The value *.v could be greater then preset. I try this with a reduced value for preset. I did not test if the value could be bigger then 9999.
best regards
LeTomas
Lt. Commander
Posted: ‎2021-11-03 07:10 AM
Hi @Anonymous user ,
I have made a video with the explanation about the counter in EcoStruxure Machine Expert Basic.
Please find below the link:
https://youtu.be/Cx8OqeJvgfI
If you want to know more about the M221 below you can find the video training(still in progress):
https://youtube.com/playlist?list=PLFqT6GhMpgpLClSpB1iH50OUr4N4mU763
Best regards,
LeTomas
Bastian_Schmitz
Admiral
best regards
LeTomas
Lt. Commander
Best regards,
LeTomas
This is a heading
