Bad Declaration, use %MX for 'BOOL' variable
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Bad Declaration, use %MX for 'BOOL' variable
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
EcoStruxure™ Machine Expert
Back to Machine and Motion Control Forum
seikosantana
seikosantana
Cadet
Posted: ‎2024-07-15 08:01 PM
1026
Hello, I am using Machine Expert 1.2.7 to program a TM241 PLC.
I am having trouble assigning an address (Modbus register) to a variable of type BOOL because at certain times, using the address %MX causes the variable to become a BIT type.
I need to keep using BOOL because I need to use the variable as an IN_OUT variable for a function block.
If I use MB or MW for the address in the declaration, during compilation, I get a "Bad Declaration, use %MX for 'BOOL' variable" error. Is there another way to assign the address and maintain the type as BOOL and not BIT?
Thank you.
  • Modicon M2xx
Bastian_Schmitz
Admiral
Posted: ‎2024-07-16 11:21 PM
Did you try to use %MWx.y instead of %MXx ?
StevenCho
Lieutenant JG StevenCho
Lieutenant JG
Posted: ‎2024-07-17 09:47 PM
I am also using ESME V1.2.
I declare the variable like below.
{attribute 'qualified_only'}
VAR_GLOBAL
xG_mccbAl AT %MX2000.0: BOOL;
xG_elbAl1 AT %MX2002.0: BOOL;
xG_elbAl2 AT %MX2002.1: BOOL;
xG_elbAl3 AT %MX2002.2: BOOL;
xG_elbAl4 AT %MX2002.3: BOOL;
xG_elbAl5 AT %MX2002.4: BOOL;
xG_elbAl6 AT %MX2002.5: BOOL;
END_VAR
