operator terminal expert Globalscripts error
  • Industrial Automation
  • operator terminal expert Globalscripts error
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
Sbracke
Crewman Sbracke
Crewman
Posted: ‎2020-07-07 07:17 AM
3945
I just spend 2 day programming my new ST6500 hmi when i encountered an error when trying to compile. The error pointed me to the globalscripts when i double clicked on it. i didn't see anything wrong with my script but when the error didn't dissapear i tried removing some parts of the script to see which part was problematic. now my entire globalscripts is empty but the error still remains and directs to the globalscripts.
error is as follows:
Selected object is undefined, Source: blockly, Path: Variablevariable_4_17
error globalscriptserror globalscripts
anyone have any solutions to this problem?
  • Smart Design & Engineering
Mufasa
Crewman Mufasa Crewman
Crewman
Posted: ‎2020-07-07 08:31 AM
3937
Hi Sbracke,
In order to investigate;
Is it possible to share the project file ?
(You can share as a private message if you want)
Thank you
Kind regards,
Posted: ‎2020-08-21 08:34 AM
In response to Mufasa
3785
Hi. Seen the same error a few times as well. Only way I god rid of it was to open a privious vertion of the program and redo the exact work. And this time the error is gone! (?) I suspected its a bug/compiler error, because it makes no sense that is is pointing to an empty script...
Mufasa
Crewman
Posted: ‎2020-08-21 08:47 AM
In response to Anonymous user
Hi @Anonymous user
Which version are you using of EOTE?
Can you share your project (You can share inside of private message.)
Kind regards,
