object transfer Periodicity of Transfer and Update Interval What's the difference
  • Industrial Automation
  • object transfer Periodicity of Transfer and Update Interval What's the difference
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2020-05-29 01:06 AM . Last Modified: ‎2020-05-29 01:10 AM
4
1969
OBJECT TRANSFER IN TACSERVER HOW TO IMPLEMENT
ATTRIBUTE PERIODICITY OF TRANSFER AND UPDATE INTERVAL FUNCTIONAL OVERLAP?
HOPE HELP ME
THANKS YOU
  • Smart Design & Engineering
Replies 4
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2020-06-01 06:50 AM
3
1953
could you please give us more details to find the right specialist?
R.-
Rodrigo G.
Industrial Automation Community manager
Posted: ‎2020-06-01 06:35 PM
In response to Rodrigo_Garcia
1943
emmm, i want to implement object transfer, but i can't understand object transfer attribute
Update Interval AND Periodicity of Transfer
i try to get help
Explanation in help:
In this field you specify how often you want the value transfer to be made, expressed in minutes and seconds. The entered number may be adjusted upwards or downwards by clicking on the scrolling arrows. You may also scroll directly to the desired value using these arrows. The periodicity may be defined in the range from 10 seconds up to 60 minutes.
Update Interval
In this field you specify the minimum transfer interval in minutes and seconds. The entered number may be adjusted upwards or downwards by clicking on the scrolling arrows. You may also scroll directly to the desired value using these arrows. The transfer will be made at the specified interval, even if the change of the value is less than the defined hysteresis (Minimum change).
i think two attribute function is identical
Rodrigo_Garcia
Commander
Posted: ‎2020-06-02 02:00 AM
In response to Anonymous user
1939
Is this related to some specific Schneider product?
Rodrigo G.
Posted: ‎2020-06-07 07:58 PM
tac vista is not schneider product?
