comunicacion pantalla hmigxu3500 y plc m241 por puerto serie
  • Industrial Automation
  • comunicacion pantalla hmigxu3500 y plc m241 por puerto serie
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2022-09-06 10:10 AM
1045
 En la configuración del vijeo designer basic no permite seleccionar puerto de comunicacion por defecto esta El COM1 pero la pantalla se comunica con El Com2, con el plc (entrando en la pantalla de conf. en el modo test de comunicacion el com1 no se comunica pero el com2 si reconoce la comunicacion.
Pero fisicamente solo tiene com2 la pantalla, como resuelvo este incoveniente.gracias
LeTomas
Lt. Commander
Posted: ‎2022-09-07 01:02 AM . Last Modified: ‎2022-09-07 01:11 AM
Hi @Anonymous user ,
It's been a long time since i do not play with the HMIGXU range but based on the Hardware guide the HMIGXU3500 only has one port, check page 14 and 16:
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=EIO0000002073.03.pdf&p_Doc_Ref=EIO0000002073
https://www.se.com/ww/en/product/XBTZ9008/rs485-cable-for-shneider-electric-plc-m200-m221-m241-m251-m340-hmi-subd9-to-plc-rj45/ (The image on the website is wrong)
Further information about the cable can be found in the next FAQ:
https://www.proface.com/support/index?page=content&country=ID&lang=id&locale=en_US&id=FA213840&prd=
If i am not wrong you can use the next file to import variables from the PLC to the HMI:
https://schneider-electric.box.com/s/cap8l6or3w901frwg3czaau42t1etgja
Good luck,
Leandro
