Vijeo Designer building error
Send InviteCancel
Posted: 2025-06-2807:24 AM
I just migrated a Vijeo-Designer 6.2 SP8 project to 6.3.2.16. To do this, I upgraded from SoMachine 4.3 to MachineExpert 2.3.
During building operation, a "Switch" window opens with the following message: "An invalid argument has been detected."
This seems to be coming from different "Switch_XXX.java" under "C:\Users\Public\Documents\Vijeo-Designer 6.3\Vijeo-Manager\M5DTemPHolder7308\X\Build\Projects\HMIS".
However, these are several natively included Java scripts. I assume that during the migration, some switch buttons were not correctly translated for the new compiler. But there is no information about which ".java" files are no longer supported and which ones are specifically used in my project? Does anyone have any ideas on how to resolve this issue?
