Vijeo 6.2 SP12 and Tia V18 / V19 project
  • Industrial Automation
  • Vijeo 6.2 SP12 and Tia V18 / V19 project
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Harmony HMI
rfond
Ensign rfond
Ensign
Posted: ‎2024-02-12 08:05 AM
2506
I would like to import some variables from a Tia V18 project. However, when I select import, I am limited to *.ap17. Is there an update available to obtain a version higher than V17?
(Version : V6.12.24 SP12 + Documentation 24-21)
Thank's
  • Process Automation Talks
  • hmi
  • vijeo designer
HattoriHanzo
Lieutenant JG HattoriHanzo Lieutenant JG
Lieutenant JG
Posted: ‎2024-02-13 04:41 AM . Last Modified: ‎2024-02-14 06:41 AM
4
2497
Hi
Unfortunately, the latest VijeoDesigner V6.3 does also not yet support TIA V18 and V19.
Depending on the HMI you use, there is our OperatorTerminal Expert which supports TIA V18. Take a look:
https://www.se.com/uk/en/product-range/62621-ecostruxure-operator-terminal-expert/
Greetings
Replies 5
HattoriHanzo
Lieutenant JG
4
2498
Hi
Greetings
rfond
Ensign rfond
Ensign
Posted: ‎2024-02-13 11:23 PM
In response to HattoriHanzo
2445
I need a new license for Vijeo 6.3 ? Or with my license 6.2 i can use latest version ?
HattoriHanzo
Lieutenant JG
Posted: ‎2024-02-14 12:29 AM
In response to rfond
2442
Yes, if you wants to upgrade from VJD 6.2 to VJD 6.3, you need to request a upgrade license (VJDUBTPRO1P).
But as I wrote before, V6.3 unfortunately doesn't support TIA V18/V19 yet.
Greetings
rfond
Ensign rfond
Ensign
Posted: ‎2024-02-14 04:18 AM
2433
"Thank you, Yes, I understand, but I think version 6.2 won't be compatible with TIA V18/V19, right? Will it only be available in version 6.3?"
HattoriHanzo
Lieutenant JG
Posted: ‎2024-02-14 05:57 AM
No, unfortunately it is not available for both version at the moment. No matter whether V6.2 or V6.3.
Greetings
