Vijeo 6.2 SP12 and Tia V18 / V19 project
  • Industrial Automation
  • Vijeo 6.2 SP12 and Tia V18 / V19 project
Bastian_Schmitz
Bastian_Schmitz Champion
38
LeTomas
LeTomas Mentor
14
ismailozinan
ismailozinan Leader
8
product field
Harmony HMI
Back to Industry Automation and Control Forum
rfond
rfond
Contributor
Posted: ‎2024-02-12 08:05 AM
3249
I would like to import some variables from a Tia V18 project. However, when I select import, I am limited to *.ap17. Is there an update available to obtain a version higher than V17?
(Version : V6.12.24 SP12 + Documentation 24-21)
Thank's
  • Process Automation Talks
  • hmi
  • vijeo designer
HattoriHanzo
HattoriHanzo Troubleshooter
Troubleshooter
Posted: ‎2024-02-13 04:41 AM . Last Modified: ‎2024-02-14 06:41 AM
4
3240
Hi
Unfortunately, the latest VijeoDesigner V6.3 does also not yet support TIA V18 and V19.
Depending on the HMI you use, there is our OperatorTerminal Expert which supports TIA V18. Take a look:
https://www.se.com/uk/en/product-range/62621-ecostruxure-operator-terminal-expert/
Greetings
Replies 5
HattoriHanzo
Troubleshooter
4
3241
Hi
Greetings
rfond
rfond
Contributor
Posted: ‎2024-02-13 11:23 PM
In response to HattoriHanzo
3188
I need a new license for Vijeo 6.3 ? Or with my license 6.2 i can use latest version ?
HattoriHanzo
Troubleshooter
Posted: ‎2024-02-14 12:29 AM
In response to rfond
3185
Yes, if you wants to upgrade from VJD 6.2 to VJD 6.3, you need to request a upgrade license (VJDUBTPRO1P).
But as I wrote before, V6.3 unfortunately doesn't support TIA V18/V19 yet.
Greetings
rfond
rfond
Contributor
Posted: ‎2024-02-14 04:18 AM
3176
"Thank you, Yes, I understand, but I think version 6.2 won't be compatible with TIA V18/V19, right? Will it only be available in version 6.3?"
HattoriHanzo
Troubleshooter
Posted: ‎2024-02-14 05:57 AM
No, unfortunately it is not available for both version at the moment. No matter whether V6.2 or V6.3.
Greetings
