Use embedded input/output in M262 PLC
Send InviteCancel
Posted: 2023-12-0706:57 AM
Hi, I am using the PLC Modicon M262 for the first time. In this case I added a digital output to test a relay output and it worked fine. Now I want to use the embedded inputs/output of this PLC in Ecostruxure Automation expert but I do not see tehm in the Hardware Configurator.
Is there any other way to create the symbolic links?
