Posted: 2024-07-22 07:47 AM
Hello to everybody,
i have a TM251 MESC plc that needs to read text data from a Keyence SR-2000 barcode reader.
The reader is connected with Ethernet, has anyone ever used these types of readers (or other types) using TCP/IP communication?
What types of instructions should I use to read/write data in TCP/IP?
I'm new to Schneider plc and I wanted to understand the feasibility of the operation.
Thanks a lot!
Posted: 2024-07-24 08:55 AM
the simplest way is to setup your Keyence barcode reader as server (see picture below).
After that create a program plc following instructions from here --> https://product-help.schneider-electric.com/Machine%20Expert/V2.2/en/exTcpUdp/index.htm#t=exTcpUdp%2...
Posted: 2024-07-24 12:15 AM
Hi I never did it, but it seems you need the EDS file from Keyence and you need to integrade them in Machine Expert. The protocoll should be Ethernet IP.
Posted: 2024-07-24 08:08 AM
so with this kind of plc (M251 MESC) is not possible to establish tcp/ip socket communication with a device?
Do i have to use the Ethernet/IP protocol anyway?
Posted: 2024-07-25 11:50 PM
Hi Adrian,
Thanks for the information!
I will try to use the instructions from the library that you indicate in the link, seems be simple.
I will let know at the end of the job.
Thanks.
