TM241 ECOSTRUXURE PTO COMMUNICATION OUTPUT
Send InviteCancel
Posted: 2023-06-1012:46 PM
Hi, I have a TM241, the fast Q0 and Q1 output are connected to stepper motor drive, for pulse train (PTO) on Q0 and pulse direction on Q1, I create a simple program using 3 MC block, power, movevelocity and stop. I also add parameter to generator pulse. The login to TM241 run ok and when I enable the movevelocity, the variable turn true, for all requirement, as power FB and MoveVelocity, But, the output Q0 and Q1 stay false. More mistake, the Q0 led on the TM241 light on, but not Q1. .... But, the output status Q0 and Q1 stay false on my computer. I don't know what to think about... ? Does the problem come from the fact that I have a basic activated trial licence, not complete... ? thanks to follow
