Posted: 2021-04-21 11:27 AM
Hello, for an opportunity we are pursuing we need to produce control documentation according German standard VGB 170C, that is commonly use for example in Power Plants.
Does anyone has a tool or procedure to produce VGB 170C compliant documentation from Process Expert or Foxboro DCS?
Another solution would be to use a compliant engineering software that could feed the engineering tool of Foxboro DCS or Process Expert. Does anyone has located any software like that. In the past we used COMOS PT software but now belonging to Siemens.
Thanks in advance.
Manuel
Posted: 2021-04-28 02:22 AM
Hello Manuel, you can probably ask to Philippe Lemoine if he can suggest someone to help.
Rodrigo G.
Industrial Automation Community manager
