Posted: 2022-09-22 09:55 PM
I need help in Software for Telemechanique TSX07 plc
Posted: 2022-10-03 09:28 AM
As you may already be aware, the TSX07 PLC was a PLC designed/sold nearly 20 years ago. The programming software was a DOS based software, part number TLXLPL707P40M. As you may expect the PLC and software are both obsolete. There was never a windows version of the software. The part number may help you in your search. The link below is from an official Schneider Electric FAQ on the topic.
Posted: 2022-10-03 01:58 PM
I still use PL7-07 to upload from TSX Nano PLCs to do migrations for our clients. It is true that PL7-07 is DOS software but it can be sucessfully ran on a windows 95 virtual machine (makes file handling a bit easier), or create a DOS VM. You can even use the USB to Unitelway programming cable (TSXUSB485) as used with a twido/premium. The trick is to install the cable drivers on the host OS then in the VM map Com1 to the virtual serial port created by the USB driver.
You used to be able to download PL7-07 from the old Schneider website (www.global-download.schneider-electric.com) but that website is no longer and I cannot find it on the new site(s).
Posted: 2023-05-14 11:33 PM
Hi @trowe,
Have you managed to find the download files for PL7-07? If not, will you be able to share the installation files?
Best regards
Leon Erasmus
Posted: 2023-05-17 05:16 PM
Leon
I found a Youtube video (in spanish) which demostrates how to install it in a DOS virtual box. The description also includes a link to download the PL7-07 Install Files, and a Virtual machine with it already installed
