ScadaPack32 - "Connection could not be established"
  • Industrial Automation
  • ScadaPack32 - "Connection could not be established"
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Klorpo
Klorpo
Cadet
Posted: ‎2024-11-26 05:30 AM
I was "playing around" with the DNP/IP/Modbus settings the other day for our 5604 Controller, which is part of a ScadaPack32 system with 6 I/O modules attached.  Anyway, since all our tags are bound with DNP addresses, I thought I could disable some features, like Modbus.  So I did that and I wrote the changes to the controller.  After doing so, anytime I want to read from the controller or just connect to it, I get the attached popup.
This is probably an easy debug but I am certain I've reset all the communication params correctly - IP, port, protocol.  I'm hoping someone has run into this before.  I'm thinking it's a secondary setting that was changed to a default but not changed back when I backed out what I had changed in the Modbus fields.  Editor is Telepace Studio 5.4.2.  Thanks in advance for any assistance.
  • Process Automation Talks
  • Smart Operations
Replies 0
