Posted: 2025-07-06 12:49 PM
Good evening team.
Has anyone witnessed hmist6400 failing to load and stops on green loading bar half way.
i have failed to access the recovery mode screen. Any trick i can try out, is there any reset button.
if the boot file is corrupted is there any way to recover it.
Posted: 2025-07-06 11:59 PM
Hi @kasmic_mike ,
We have the possibility to access into the "Broken Mode" of the HMI that will allow us to re-download the application in case a problem showed up in the device. Depend on the firmware of the HMI you have two methods (which i believe you tried):
EOTE v3.2 SP2 or higher: https://youtu.be/wo2L15GZWzw
EOTE Before v3.2 SP2: https://youtu.be/S1CwAZUZB70
If the Broken mode does not work then you will need to contact the Service or Technical person (ADE / PAE /SAE) of Schneider so they can perform the HMI Recovery (Aurora). This is a process only done by Schneider and can not be distributed to the customers.
Best regards,
Posted: 2025-07-23 02:35 AM
Thanks for the response and the advise given However i ahve tried all the above solutions to the harmony HMIST6400 but it has failed.
Posted: 2025-12-01 08:11 AM . Last Modified: 2025-12-02 10:06 AM
@kasmic_mike Can you try this and tell us if it work?
https://community.se.com/t5/Industry-Automation-and-Control/HMIST-6400/m-p/401787
@LeTomas I belive you refer to the next procedure:
For the HMISTO6400SL exist this firmware whit almost the same steeps
https://www.se.com/za/en/download/document/HMIST6400SL-fw/
