Project Signature Mismatch Error in Vijeo Designer v6.2 SP4
  • Industrial Automation
  • Project Signature Mismatch Error in Vijeo Designer v6.2 SP4
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Lakjaya1
Crewman Lakjaya1
Crewman
Posted: ‎2025-11-04 03:18 AM
340
Hello, When we try open a Vijeo Designer project file using the software Vijeo Designer 6.2 SP4, the above error message was given. The project file details are as follows.
Version Created (09/02/2019) - 6.2.4 Build 3501
Version Modified (30/06/2022) - 6.2.4 Build 3514
We tried opening the file using v6.3 as well, but it gave the same error message.
Can i know the reason for this error and a compatible version that this file can be opened?
  • Process Automation Talks
ismailozinan
Commander ismailozinan Commander
Commander
Posted: ‎2025-11-10 04:32 AM
In response to Lakjaya1
Could you please try with Vijeo Designer Basic software? Thanks,
Replies 5
ismailozinan
Commander
Posted: ‎2025-11-08 04:03 AM
317
Unfortunately, it’s not possible to open higher-version projects with lower versions. That’s why you received this warning. I’m currently using version 6.2 SP12. Honestly, the program and software version you have are quite old. I believe if both of you use version 6.2 SP12, there shouldn’t be any problem. I hope your issue gets resolved. Wish you good luck with your work.
Best Regards,
Lakjaya1
Crewman Lakjaya1
Crewman
Posted: ‎2025-11-09 05:36 AM
In response to ismailozinan
I tried opening the project file after upgrading to version 6.2 SP12 as well, but still could not open it.
Lakjaya1
Crewman Lakjaya1
Crewman
Posted: ‎2025-11-09 06:50 PM
289
I tried opening the file after upgrading to version 6.2 SP12 as well, but it did not work. Even with version 6.3 also it did not work
ismailozinan
Commander
Lakjaya1
Crewman Lakjaya1
Crewman
Posted: ‎2025-11-11 01:28 AM
Thank you! It worked and the file opened succesfully.
