Nom Module with M580 controller by Using control expert v15.3
  • Industrial Automation
  • Nom Module with M580 controller by Using control expert v15.3
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
bhushanshiv
bhushanshiv
Cadet
Posted: ‎2024-03-07 04:15 PM
857
We are facing the issue in NOM module while we are using 8 device.
For example: if our 3 device is power on and 5 device is power off than after the certain hours NOM module got hanged/ Not reading the data from salve device.
As it's need to be work on if all the devices is connected in one loop cable and some devices is power off then why communication is breaking.
Controller:-M580
NOM Module version: 1.6
Control expert V15.3
Pls guide for further action.
  • Hybrid DCS
  • nom
Marian_Pavlik
Ensign Marian_Pavlik Ensign
Ensign
Posted: ‎2024-03-19 02:15 PM
Issue will be in calling communication functions and defined timeouts in GEST table vs. timeout of serial line. If it's not done correctly then buffer of serial link could overflow.  Too many new communication function demands even older ones are waiting to timeout lead to buffer overflow. Buffer is same for both ports of BMXNOM0200 so problem of one will lead to error on both.
