Need Help
  • Industrial Automation
  • Need Help
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
alvi13akif
Crewman alvi13akif
Crewman
Posted: ‎2019-10-01 03:21 AM
5400
Need Help
Capture.PNGCan anybody help me whats is wrong here. i am new to this so need sugetion
  • Smart Operations
Eric_Coudurier
Lt. Commander Eric_Coudurier Lt. Commander
Lt. Commander
Posted: ‎2019-10-01 10:08 AM
4
5381
It seems because an other line reset the %M13.
The visualisation of the variable is normally done at the end of the cycle, That's why you can see a false result on an equation which seems to be true. The %M13 is used in the other lines and is reset by the other logic.
Replies 5
Eric_Coudurier
Lt. Commander
4
5382
alvi13akif
Crewman alvi13akif
Crewman
Posted: ‎2019-10-01 09:34 PM
In response to Eric_Coudurier
5374
Thank you for your reply let me try and inform you
alvi13akif
Crewman alvi13akif
Crewman
Posted: ‎2019-10-02 12:54 AM . Last Modified: ‎2019-10-02 12:55 AM
1
5369
Thank you.
Your solution worked
You save my day love and respect from Bangladesh
Eric_Coudurier
Lt. Commander
Posted: ‎2019-10-02 01:11 AM
In response to alvi13akif
When you work in Ladder a very good practice is to write the coils only once in the program. It's a continuous flow, so when the coil is written several time only the last write will be used.
The SET, RESET coils may be used instead the direct coil, but the good practice is the same: one equation to set and one equation to reset the coil.
alvi13akif
Crewman alvi13akif
Crewman
Posted: ‎2019-10-03 07:06 AM
Can u give me a wiring diagram for connecting m221 serial (rj45) to HMI rs485 dp9 comunication. And what will be the setup in HMI program. I am now stuck on this. And Google is confusing me and can't find the accurate one about it
I need it will you please help me?
