Names and Device DDT
  • Industrial Automation
  • Names and Device DDT
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Aqui
Crewman Aqui
Crewman
Posted: ‎2024-04-15 01:48 PM
939
Hello
I would need to know if there is a simple way to manually assign names to the Device DDT type I/O variables on M580.
For example, exporting the I/O names from Eplan or similar to a file and somehow importing them into the Control Expert Data Editor list (in this case to the data xxxxCanalxxxx.VALUE)
Five or six variables can be write down well by hand, but 500 or 1000 are a little more work...
Thank you
  • Training
MatthewM
Lt. Commander MatthewM
Lt. Commander
Posted: ‎2024-04-17 02:49 PM
Hi Aqui,
The attached has not been moderated yet so I can't see exactly what you are trying to do and with what devices types, but I am assuming you are trying to alias a variable to a channel using the Device DDT.  You can write a script to generate the following:
<VariablesExchangeFile>
   <dataBlock>
      <variables name="LH001" typeName="T_U_DIS_STD_CH_IN">
         <comment>Canal Level Switch 1 Field Input</comment>
         <attribute name="AliasOf" value="PLC0_D00_R01_S04_DDI_3232.DIS_CH_IN[0]" />
      </variables>
      <variables name="LH002" typeName="T_U_DIS_STD_CH_IN">
         <comment>Canal Level Switch 2 Field Input</comment>
         <attribute name="AliasOf" value="PLC0_D00_R01_S04_DDI_3232.DIS_CH_IN[1]" />
      </variables>
   </dataBlock>
</VariablesExchangeFile>
Then:
LH001.VALUE is equivalent to PLC0_D00_R01_S04_DDI_3232.DIS_CH_IN[0].VALUE
LH002.VALUE is equivalent to PLC0_D00_R01_S04_DDI_3232.DIS_CH_IN[1].VALUE
Hopefully that helps.  The structures and types will vary with different I/O card types.
