NTC 1.8 Kohm thermistor Characteristic curve
  • Industrial Automation
  • NTC 1.8 Kohm thermistor Characteristic curve
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
HamzaZghoul
HamzaZghoul
Cadet
Posted: ‎2024-08-01 12:13 AM
686
Hello
I am working on a project that need to take readings of NTC thermistor to Allen bradley Compactlogix (1769-L33ER), so I need to convert these reading from resistance to temperature using steinhart-hart equation, and as you know A, B, C coefficients are need for correct conversion.
I was checking the datasheets for the field sensors and there is no information about steinhart-hart coefficients and not even the R-T table or characteristic curve. How can I get the these Information to make the conversion?
The sensors are:
-STP100, STP 101 NTC Immersion pipe temperature sensor 1.8 Kohm
-STD190 NTC 1.8 Kohm
Thank You
  • Process Automation Talks
Bastian_Schmitz
Admiral
Posted: ‎2024-08-01 12:47 AM
Hi, check the attached document
