Machine expert script
  • Industrial Automation
  • Machine expert script
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Automa
Automa
Cadet
Posted: ‎2023-12-04 12:51 AM . Last Modified: ‎2023-12-04 12:59 AM
754
I am trying to automate configurations of TM3 modules in machine expert using python script.
I am able to create a TM3AM6/G and change  the I/O mapping but I have not been able to change IO configuration of each input and output.
I can read out the values of IW0 {0, 32, 0, 12000, 0, 0} but I can not modify the values.
for IO in IOModules.get_all_parameters():
    if IO.VisibleName=="IW0":
        print(IO.Value)
Result: {0, 32, 0, 12000, 0, 0}
  • Process Automation Talks
Automa
Automa
Cadet
Posted: ‎2023-12-19 12:21 AM
In response to RoseMciver
Hi, I have tried to modify it and use the set_parameter method but this results in corrupt module. In my opinion I need to go down one more level to see all the individual sub elements and with a different method change them one by one.
I can see the sub elements in the modules .xml file.
