MQTT M262 certificate
Send InviteCancel
Posted: 2023-05-0412:28 AM
Object: Publish data from M262 PLC at a facility to a customer’s MQTT broker. I have received Server certificate, Client Key and Client certificate from customer as well as mqtt-broker-address. I am using ME 2.0.
Approach: I have used the MQTT example from Schneider and modified it so that it does not require an IP address and accepts the server certificate and client certificate. When I enter the trusted partition of the PLC I am able to place the client server certificate and the client certificate, but client key is not accepted. There is also no mentioning of this in Schneider Electric MQTT manuals.
Problem: I do not know where to place the client key and the error message I get in MainVisu is "CertificateNoKey".
Additional info: This exact issue will also be an issue for anyone trying to publish to AWS.
