Is it possible in structure text to implement a function within a Derived FB type section
Send InviteCancel
Posted: 2023-12-2210:33 AM
I'm on control expert classic. I implemented a section of a Derived FB Type in structure text.
There are some pieces of code that are repetitive in the code and I like to put them inside of a function
ex :
FUNCTION Foo : REAL
VAR INPUT
BAR : REAL;
END_VAR
BEGIN
Foo := BAR ;
END_FUNCTION
(*BEGING OF THE DFB*)
OUT_DFB_1 : = Foo(IN_DFB_1);
OUT_DFB_1 : = Foo(IN_DFB_2);
So is it possible to nest function inside of DFB sections? Can't find any documentation on this topic.
