Invalid file format - Error reading the file
  • Industrial Automation
  • Invalid file format - Error reading the file
Bastian_Schmitz
35
LeTomas
14
RoozeeR
Lt. Commander RoozeeR Lt. Commander
6
JerryBartlemay
6
EcoStruxure™ Control Expert
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-05 01:43 AM . Last Modified: ‎2022-12-05 01:45 AM
2
2258
Hey there,
I am having an issue to load my .stu Control Expert project. This is not the first time I get this error. Usually I have used the .BAK backup file to fix it, but this is starting to happen often so I wanted to ask you if you can fix this or tell me how to fix this issue?
P.s. I am working on a virtual machine, I don't know if that have anything related to this, and the version I'm using is V15.0-201016B.
Best regards,
Grétar Már
Robert_Willis
Lieutenant JG Robert_Willis Lieutenant JG
Lieutenant JG
Posted: ‎2022-12-09 06:59 AM
2223
1. What version of EcoStruxure Control Expert was used to create the file? Please include a list of any hotfixes that have been installed.
2. Go to the help about EcoStruxure Control Expert meu option and select the Perform self-test dialog box. This will perform a validation of all of the files associated with ECE and then check your FFB libraries. If this test fails, then you will need to reload ECE V15.0
gretarmark_
Ensign gretarmark_
Ensign
Posted: ‎2022-12-15 01:06 AM
In response to Robert_Willis
Hi Robert,
1. The version is V15.0 - 201016B.
2. I did the self-test and everything looked good. I got "check ok" in all boxes under "current status" column.
