Send InviteCancel
Posted: 2022-12-0501:43 AM. Last Modified: 2022-12-0501:45 AM
Invalid file format - Error reading the file
Hey there,
I am having an issue to load my .stu Control Expert project. This is not the first time I get this error. Usually I have used the .BAK backup file to fix it, but this is starting to happen often so I wanted to ask you if you can fix this or tell me how to fix this issue?
P.s. I am working on a virtual machine, I don't know if that have anything related to this, and the version I'm using is V15.0-201016B.
Posted: 2022-12-0906:59 AM
1. What version of EcoStruxure Control Expert was used to create the file? Please include a list of any hotfixes that have been installed.
2. Go to the help about EcoStruxure Control Expert meu option and select the Perform self-test dialog box. This will perform a validation of all of the files associated with ECE and then check your FFB libraries. If this test fails, then you will need to reload ECE V15.0
