How to change predefined image color?
Showing results forย
Did you mean:ย
  • Industrial Automation
  • How to change predefined image color?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Schneider
HMI Screen Templates for EcoStruxureโ„ข Operator Terminal Expert
jhonut
Ensign jhonut
Ensign
Posted: โ€Ž2021-01-15 04:13 AM
5182
Don't know if the question is put in the right section, but I'll give it a try.
I'm using EcoStruxure Operator Terminal Expert (v 3.1, SP 1B) and I'm trying to change the color of a pump (predefined image) when a button is clicked, but I don't see any possibility in pump's property menu . I have managed to change the color of a rectangle (shape) helped by this example.
My question is how could I change pump's color?
Many thanks in advance!
  • Smart Design & Engineering
  • Training
  • change pump color
  • ecostruxure
  • pump
Replies 7
LeTomas
Lt. Commander
Posted: โ€Ž2021-01-15 04:46 AM
5175
Hi @jhonut ,
I am not sure but i think you need to modify the transparency of the object and enable the shadow and link a variable to the color.
Like the next video example:
https://schneider-electric.box.com/s/sfmtz2pinnx8e1rfxrlmo44axkmea6zt
I hope this helps you.
Best regards,
LeTomas
jhonut
Ensign jhonut
Ensign
Posted: โ€Ž2021-01-15 05:02 AM
In response to LeTomas
5171
Thanks for your reply, @LeTomas !
I thought there's another way to do it. I tried to do it, following your example, with a bool variable but the shadow color isn't changing. I must use converters in order to change the shadow's color?
LeTomas
Lt. Commander
Posted: โ€Ž2021-01-15 05:15 AM
In response to jhonut
5166
Hi @jhonut ,
Probably my example is one way to do it. I just gave my idea ๐Ÿ™‚
Please find below the link for an example using converters with boolean variables but you can also do it with an int variable like my previous example video.
https://schneider-electric.box.com/s/z07cii6wctwkrulfwpxsbb7goiow1jgv
Best regards,
LeTomas
jhonut
Ensign jhonut
Ensign
Posted: โ€Ž2021-01-15 05:20 AM
5164
Ok. Thank you for the provided solution. In my opinion, normally it should color the entire pump, not only the shadow. I don't remember if this was possible in Vijeo Designer.
Bastian_Schmitz
Admiral
Posted: โ€Ž2021-01-15 05:41 AM . Last Modified: โ€Ž2021-01-15 05:42 AM
5162
Alternativ to this solution you have the possiblity to draw the pump completly in ESOTE.
In this case you have the full flexiblity regarding to the colors.
You can see what I mean in the follow Video. At the end is a sample for a booster pumping application.
Link to video Link
You can find the sample project here
Demo Project HVAC objects ESOTE
You can reuse the Objects via copy and past
jhonut
Ensign jhonut
Ensign
Posted: โ€Ž2021-01-20 11:56 PM . Last Modified: โ€Ž2021-01-21 12:02 AM
In response to Bastian_Schmitz
5133
@Bastian_Schmitz, thanks for replying and sorry for the delay.
How could draw a pump in EcoStruxure Operator Terminal?
Bastian_Schmitz
Admiral
Posted: โ€Ž2021-01-21 10:13 PM
All Objects form the video I shared are drawn completly in ESOTE.
If you activate the grid in ESOTE you can realy good draw object.
You have also the possibility to combine image files with additional drawings.
To do this you can use the grouping function which I used also.
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
