How to allow external gateway to read data from P342020 CONTROLLER (UNITY PRO)?
Send InviteCancel
Posted: 2024-08-2402:15 AM
I want the FS-QS-1510 Field server quick server gateway to read data from my schneider m340 controller (unity pro). I connected the gateway and plc through ethernet. Need to convert data from ethernet to BACNET. The gateway uses a csv (excel) file for configuration. I watched some tutorials available but no use.
