How do i change io address from %I.2.0 to %I1 on M340
  • Industrial Automation
  • How do i change io address from %I.2.0 to %I1 on M340
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Vusimuzi
Vusimuzi
Cadet
Posted: ‎2024-10-31 03:15 AM
1314
Good day,
My name is Vusi am still new on control expert, i have a project which uses Topological memory management
starting address of the input card is %I0.20 which is on slot 2, however i want to change the address to %I1 and so forth this will be easy for SCADA addressing . i tried to change the address on data editor when i build it gives me an error saying the instance is located on an address that is not configured please help this on M340 2020 CPU
  • Process Automation Talks
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2024-11-06 01:14 AM . Last Modified: ‎2024-11-06 01:16 AM
2
1272
M340 uses topological addressing by default. If you need to write to %Ix State RAM addresses, you can perform following steps:
1: Select in the CPU configuration the "Mixed Topological and StateRAM" (double click the CPU). Also set the STATERAM size to the size needed.
2: Create a Module (if not already) and double click the module. Select on the memory tab "Mixed Topological and STATERAM and set the starting address (ex. %I1):
Note: I used Control Expert v16
Best regards,
R.Roozee
Sr Solution Architect (SAE Master)
RoozeeR
Lt. Commander
2
1273
Best regards,
R.Roozee
MatthewM
Lt. Commander MatthewM
Lt. Commander
Posted: ‎2024-11-06 08:14 PM
In response to RoozeeR
Huh, I didn't know you could do that!  I will have to retract my previous reply.
Vusimuzi
Vusimuzi
Cadet
Posted: ‎2024-11-06 10:07 PM
Thanks Roozee that helps
