Hold Delay activates popup window, but how can you see what objects cause trigger this?
Send InviteCancel
Posted: 2024-04-2312:05 AM
Hi all,
Ok, let me give you some more info as the title isn't that obvious.
I have a popup window used to enter serial numbers, model numbers etc. This is security protected. This works fine.
To get to the login page we have a switch on another panel which you need to keep held down for 3 seconds to display the popup window. This also works fine.
The problem was, I had no idea which button it was because no panel report or variable report seems to give any clue as to what triggers it or what actions are tied to it. Is that correct?
So ideally when I initiated the panel report it would have said 'oh yes, here's the list of actions/methods setup for this panel and also the variables tied to said action/method' (which would be the switch), but it seems like there's nothing like that available so there's no way to know what a switch is setup to do without going through each switch individually. Is that correct or am I missing something obvious?
