Posted: 2020-06-24 08:55 PM
I'm currently trying to set-up a M241 PLC to communicate with a Rigol Multimeter via RS-232 using the ASCII manager.
I have had success sending commands to the multimeter (and hyperterminal on a PC) from the PLC using the example below from the
SoMachine Modbus and ASCII Read/Write Functions PLCCommunication Library Guide
I have taken this example and modified it in order to try and receive a basic message, initially from hyperterminal, See 'Current receive example' below, however I am yet to get this working.
Can anyone share an example of code used to receive a message using this SEND_RECV_MSG function block? Or provide a hint as to where I am going wrong?
Send Example:
Current Receive Example:
The PLC is connected to my computer using a RJ45 to serial cable and a serial to usb converter.
I believe I have the ascii manager and cable set-up correctly as I am able to send messages from the PLC to hyperterminal.
Thanks in advance,
Kiwi_Karl
Posted: 2020-06-25 04:05 AM . Last Modified: 2025-10-13 11:29 PM
You can use programme that at linked.And also You can find video at attached for explaining programme.But video is turkish language.
Best Regards,
Posted: 2020-06-29 02:14 PM
Hi ismailozinan,
Thank you for the program. It was very helpful, I've got it working now!
Regards
Posted: 2023-10-12 01:34 AM
Good morning,
I have exactly the same problem but the file is no longer available ? Could you put it back online? Or put a screenshot? Or the link for the video ? thanks in advance
Posted: 2024-08-09 10:03 AM
Hi All i am also try to get it done will update you after taking trial.
here i have one customer software which will send me the query like below
RON 2,5,7 = means Realay on of output Q2, Q5, and Q7
and
when it is on from PLC then i need to send the feedback or status to that software like
Status 2,5,7 = si it will understand the output is on.
also there are many more CMDs to PLC and Status to Software.
I wiling to do much more also hopping your file will help us as I read above comments.
Posted: 2025-10-13 10:09 PM
@ismailozinan could you confirm the access to the second link?
Thank you🙂
Posted: 2025-10-13 11:28 PM
Hi @StevenCho ,
i checked it. Both the working programs and the videos showing how they work are available in the folder.
Posted: 2025-10-13 11:43 PM
Somehow there is notice about access authority😂
Or You can share the file throught email.
(steven@enes.co.kr)
Thank you.
Posted: 2025-10-14 12:16 PM
I opened to everyone.Could you please try again?
