HMI splash screen won't display
Send InviteCancel
Posted: 2024-04-0307:29 AM. Last Modified: 2024-04-2311:46 PM
Hi all,
I have a HMIGTO2310/2315.
In the hardware options I'm choosing to display our company logo as the splash screen, however it's not working.
I've set the image size to that of the panel as I wondered if the physical image size was causing an issue. If you scale it larger than the panel the build fails, but it never complains if it's miniscule (I set 2 x 2 pixels!)
