EcoStruxure Architecture Builder
  • Industrial Automation
  • Re: EcoStruxure Architecture Builder
Bastian_Schmitz
Admiral Bastian_Schmitz Admiral
35
LeTomas
Lt. Commander LeTomas Lt. Commander
14
JerryBartlemay
Lieutenant JG JerryBartlemay Lieutenant JG
7
Back to Industry Automation and Control Forum
Moulaye
Crewman Moulaye Crewman
Posted: ‎2022-07-25 08:43 AM . Last Modified: ‎2025-05-29 01:01 AM
8417
The new version, called version 6.1 is available. for download here. You can learn more about the new version with this youtube video.
The new main features the tool introduce are :
  • New landing page allowing the configuration of an EcoStruxure Control Expert , or an EcoStruxure Automation Expert or an EcoStruxure Power Digital Project and show the status of the project.
  • EcoStruxure Power Digital Performance Analysis
  • Create horizontal and/or Vertical Columbus for a location
  • New Custom catalog allows now to configure more devices network protocol, custom device for the Control room
  • Improve the Dependability calculation of the tool.
  • An automatic software selector for control room creation
  • Dual CRA BMECRA31310(H) control unit configuration
  • The compliance with EcoStruxure Control Expert V15.1 and v15.2
Don't hesitate to contact me for any question
  • Smart Design & Engineering
  • EAB
  • EcoStruxureArchitecturebuilder
  • v6.1
Moulaye
Posted: ‎2023-01-23 01:58 AM . Last Modified: ‎2023-01-23 01:59 AM
In response to Erik_Huysmans
Hi @Erik_Huysmans ,
I am really glad to read you are using our tool when we are always delighted to support our users.
Regarding your question,  yes you can use the custom catalog that allow you to add 3rd party devices into the Builder catalogue and then Drag and Drop into your architecture ( see video attached)
you can find this custom catalog on the tool bar
then you will see a windows opened where you can create your custom device. It can be either Device, Software, network device etc..
For instance to create a device you have to specify the name (Reference) associate to a familly ( e.g. drive) and you can attach documentation or images ( optional). You must select the network connexion type.
once the device created you must click on save, then save your custom catalog.
You can see your newly created device on the edition tab
 you can use the device by Drag and Drop
Best Regards
Replies 10
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Posted: ‎2022-07-27 04:58 AM
Thanks for sharing!!
Rodrigo G.
Industrial Automation Community manager
Erik_Huysmans
Lieutenant Erik_Huysmans Lieutenant
Lieutenant
Posted: ‎2023-01-20 04:48 AM
7856
Hello @Moulaye
I'm Erik from =S= Belgium. I'm using Architecture Builder to create a network design of the equipment we have in Belgium. I can see there is already a good library of =S= devices. Is there also a place to download catalogs of older materials ?
Example, I want to add some Sepam 80, I don't see it in the library..
Moulaye
Hi @Erik_Huysmans ,
Best Regards
DanielHG
DanielHG
Posted: ‎2023-03-15 09:23 AM
7599
Hello, I'm using Ecostruxure Architecture Builder for designing a Hot Standby M580 Topology with Connexium switches and fiber optic, I have already finished but I do not know how to select the switches with fiber instead of copper.
Is there a way for doing this ? or Architecture Builder only allows copper connections?
Moulaye
Posted: ‎2023-03-16 03:26 AM
In response to DanielHG
7589
Hi Daniel,
if your Hot Standby is connected to the control network to change it to fiber you just have to go the menu option of the control network and select the option fiber optical
DanielHG
DanielHG
Posted: ‎2023-03-16 08:24 AM
In response to Moulaye
Hello @Moulaye thanks for the prompt response, I see that for operation and control Network is it possible to change to fiber, but I meant for device Network the only way to change to fiber is using the NRP module, the only thing is that in our topology we are using DRS Switches just as described in Modicon M580 Complex Topologies document. (see image attached). Thank you again and best regards
peter.wietsma
peter.wietsma
Posted: ‎2023-04-06 10:48 AM
Hello, I tried using the link to download but it no longer works.  Is there another location to download this tool?
Thank you.
Tushar
Tushar Cadet
Posted: ‎2023-10-05 08:11 AM . Last Modified: ‎2023-10-05 08:11 AM
The Download link does not work . Does anyone have the latest link to download/install ?
mncaride
mncaride Cadet | EcoXpert Master
Posted: ‎2023-10-09 10:08 AM
The Download link does not work. Please review.
ScottGriffiths
ScottGriffiths
Posted: ‎2023-10-09 06:56 PM
The link is no longer available, please update.
