Eco Stuxture Operator Terminal Panel , whith İnteger varibale value,multiple İmage Visibity or animation?
  • Industrial Automation
  • Eco Stuxture Operator Terminal Panel , whith İnteger varibale value,multiple İmage Visibity or animation?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Kursuncu
Kursuncu
Cadet
Posted: ‎2022-07-01 02:33 AM
2
1301
How can I make a multiple image animation with integer value on the Eco Stuxture Operator Panel terminal program?
LeTomas
Lt. Commander
Posted: ‎2022-07-05 02:35 AM
Hi @Kursuncu ,
You can create contents with the images, for example content 1000 , 1001 and 1002.
In those contents you can put your images.
In a screen add a content view and in the properties of content id assign a variable that will allow you to change the content from 1000 , 1001 and 1002.
If you are using for example a variable that has the values 0 , 1 and 2 to show those images before then you will need to add a converter type "Range" so you can have the following:
0 --> 1000
1 --> 1001
2 --> 1002
Finally, in the content view that you have add you will need to link to the variable the converter.
I believe this is one way to do it.
Paul_Derbyshire
Ensign Paul_Derbyshire Ensign
Ensign
Posted: ‎2022-07-05 04:02 AM
Hello Kursuncu,
There are many methods to accomplish what you are after.
  1. Attached is a 3.2.SP1 project which demonstrates changing between pictures in succession using a script.  The example uses a time based trigger in script.  However you can change it to an integer.   No limit for number of states.
2. Another option is to use an "N-State Lamp".   Default mode is integer.   In properties, [Shape] -> [Basic] you can set the image for each state.   Limit today is 256 states.
3. Another option is content displays.  1 content screen or each imagine.  Change the content screen # in the content display
If you need more options please let us know.
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
27.1 - Picture Display GIF-Style Animation.zip
