Posted: 2021-07-15 12:12 AM
Hi All,
Im trying to send the configuration to T300, but it showing "Error: Connection not established. Check the communication parameters"
I had config my PC, and successfully ping to T300 (Default IP: 192.168.0.254), also can login to check T300 via the web browser.
Here is the screen capture
Many thanks for your assistant.
Posted: 2021-07-30 08:02 AM
Please contact the global tech support at SM EUR Global-NA-Tech-Support <global-na-tech-support@schneider-electric.com>, they will be able to help you investigate why you face the issue.
Your Easergy Builder software version is V1.6.7 but that you have selected to build a configuration for V1.5 (currently we are on V2.7.1). Why is that?
Thank you
