Counter Module TSXCTCY2C UPGRADE
Send InviteCancel
Posted: 2025-03-1709:39 PM
Hello everyone, I have a project to upgrade the from TSXP571634M to M580, in the previous type there was a TSXCTY2C counter module, and will be replaced with BMXEAE0300. I want to ask about the Replacement of the Module, on TSXCTY2C there are Commands DIR_E NAB with the address (%Qr.mc.0) and Command FLT_A CK with the address (%Qr.mc.3) both bits are used in the logic program, but for BMXEAE0300 there are no bits (DIR_ENAB and FLT_ACK), please give me advice, when using BMXEAE0300 whether there is a replacement bit for the two bits, so that when migrating it does not change the logic program.
