Control Expert V15 or above - how to use global variables inside a DFB?
  • Industrial Automation
  • Control Expert V15 or above - how to use global variables inside a DFB?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
FSE_Grahovac
FSE_Grahovac Cadet
Cadet
Posted: ‎2023-11-21 11:53 AM
4
3090
Hi all,
apparently, since CE V15.0, it is possible to use variables defined in the variable list (outside the DFB) inside an DFB. I tried this with CE V15.2 and it does not work. Can anyone say anthing to this topic?
  • Process Automation Talks
Replies 4
Bosswaffle
Lt. Commander Bosswaffle
Lt. Commander
Posted: ‎2023-12-06 03:54 PM
Inside your DFB address the external variables as "PROJECT.xyz" where xyz is the external variable you'd like to use.
brightonrust
brightonrust
Cadet
Posted: ‎2024-01-24 03:18 PM
This is giving me an error. It's saying there is a variable conflict.
Michael_Chan
Commander Michael_Chan Commander
Commander
Posted: ‎2024-01-25 10:16 PM
2862
There are two ways to get your global variables into the DFB:
1) Use the "MOVE" function block to move your global data to a declared "Public" variable within the DFB, or
2) Use the "inputs/outputs" pin of the DFB as the direct connection to the global variable.
Michael Chan Kum Yuen
RoozeeR
Lt. Commander RoozeeR Lt. Commander
Lt. Commander
Posted: ‎2024-01-29 01:49 AM
In response to Michael_Chan
Or use the global variable direcly in the DFB code named as "Project.Global_Data"
R.Roozee
Sr Solution Architect (SAE Master)
