Control Expert Derived data types to Vijeo Designer
  • Industrial Automation
  • Control Expert Derived data types to Vijeo Designer
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
Posted: ‎2021-08-04 04:14 AM
2779
I am using Control Expert and Vijeo Designer and how to import the derived data types created in Control Expert to Vijeo Designer as Used data type
  • Training
AlastairF
AlastairF Schneider Alumni (Retired)
Posted: ‎2021-08-04 06:08 PM
2765
The latest version of Vijeo Designer (V6.2 SP11) supports all variable types in Control Expert applications.
Your best approach is to use the Link Variables option and link to your Control Expert application. stu, xvm file types are supported. You would need to export your CE variables in xvm format to use that.
Refer to the VJD Help file Section 6.3.4
Posted: ‎2021-08-04 09:19 PM
In response to AlastairF
2761
I have user Derived variables in Control Expert and I have similar user defined Variables in Vijeo Designer and is there any possibilities of moving the User Derived variables from Control Expert to User defined variables in Vijeo Designer other than linking variables. I tried exporting the User derived variables from Control Expert its format is .xdd but when I tried to import the file is Vijeo Designer it accepts .VJDDataTypes files only. Even I tried to recreate same as I have attached below I am facing a issue like I cannot insert a structure inside a structure in User Defined Variables in Vijeo Designer. May I know is there any option to do this process.
AlastairF
Posted: ‎2021-08-05 07:53 PM
In response to Anonymous user
You should be able to do this is by manually creating identical structures in Control Expert and VJD and using located addressing to get the data.When you assign the address in Control Expert, check that the structure elements pick up on the same addresses in VJD. M580 PLC's use double word addressing and VJD will assume consecutive addressing unless you override where necessary.
I think that unless you link variables you can't use the Data Dictionary function.
