Posted: 2022-06-21 01:18 AM
I am trying to communicate LMC058LF42 with my pc for uploading programme.,using Somachine V4.3.
At present i am giving power 24vdc to 1.5(+)and 1.6(-) to the power module .EXP and I-O led are green steady on .CTRL led is flashing green. But my RUN/MS led is steady red when powering up. And ethernet led are not lit. As I am trying with normal ethernet cable here. i want to know the following:
- what is the procedure for proper connection both hardware and software?
- will normal Lan cable will work or i should only use manufacturer cable? i think for both pinout is same.?
- what is the procedure for uploading programme ,from one source i saw that i need to download the source application or source code to plc for enabling upload?
Posted: 2023-11-17 04:23 AM
Hello, if the straight red RUN Led means "HALT after system error detected".
The network cable to connect can be a common network cable.
You will only be able to upload the program if the source code is inside the PLC and often for security purposes it is not made available.
